[postgis-users] Hibernate Spatial Postgis 3D
Max postgis at lists.meisel.cn
Thu May 8 00:25:09 PDT 2008
Hallo Drew,
i know, but did you tried p.getCoordinate().z, that should return the
expected value. This Value actually should be stored in the database
using the new code on the svn, but maybe i'm wrong...
Max
> Hiya Max,
> But the WKTReader which provides you with the Point object to persist - does not support 3D.
> See the following:
>        String wktPoint = "POINT(12 14 15)";
>         WKTReader reader = new WKTReader();
>         try {
>             Point point = (Point) reader.read(wktPoint);
>             System.out.println(point.toString());
>         } catch (ParseException e) {
>             e.printStackTrace();
> The result will be: POINT (12 14)
> HTH
> Drew
> On Thu, May 8, 2008 at 3:32 PM, Max <postgis at lists.meisel.cn> wrote:
> Hallo Drew,
> >  this is right, 3D support seems to be only in the SVN-Version, its
> >  Version 94 in the repository, should be from march this year.
> >  Max
> >  > Hiya Max,
> >  > Which version of the library are you using? It looks like 3D support is only in svn.
> >  > Drew
> >  postgis-users mailing list
> > postgis-users at postgis.refractions.net
> > http://postgis.refractions.net/mailman/listinfo/postgis-users
