[postgis-users] Having problemas to convert SHP to PGSQL
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Wed May 14 11:35:40 PDT 2008
Syntax for command please ...
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of George R. C. Silva
Sent: Wednesday, May 14, 2008 2:27 PM
To: PostGIS Users Discussion
Subject: [postgis-users] Having problemas to convert SHP to PGSQL
hello all!
Once again i come with a issue for you the experts :P
I´m having trouble converting a shapefile to postgis schema, and nothing
will make it work.
the shp2pgsql actually runs, but at the end, no table is added or
populated. I even tried converting using QGIS 10
I will attach a zip of the shpfile. SRID is 29182.
Ive checked within ArcGIS is the shp is valid, or has problems, and nothing.
My postgresql is 8.3 and latest pgis.
