[postgis-users] Understanding speed issues
John Abraham jabraham at ucalgary.ca
Wed May 14 14:29:57 PDT 2008
Hello postgis friends.  I'm doing a simple update query on a table of
138000 records.  The update query is
update Parcels
set pecastype=' ', pecassqft=0, yearbuilt=1993;
It takes over 10000s.  Why might that be ?
I've been googling a bit, and I understand that because of the
transaction nature of the postgresql system, each of these updates would
be an "delete" and an "insert".  That, I suppose, *might* explain the
slowness.  But how to get around it?  Are there database config
setttings or options in the query that might help?
PostGIS relevance:  It has a GIST index, but I'm not changing the
geometry at all.  But if it's a delete and an insert, maybe it has to
keep rebuilding the GIST index, which could be slow?
Thanks in advance for any help,
PS also my hard drive is almost full; I'm working on that problem but I
can't see how it could be too relevant.
John Abraham
