[postgis-users] Topology and Triggers
Kevin Neufeld kneufeld at refractions.net
Thu May 15 21:52:41 PDT 2008
Bruce Rindahl wrote:
> Has anyone thought about the Arc/Info coverage model?  The idea would
> be to have a table with line geometries and attributes reflecting the
> left and right polygon ids.
Absolutely.   Much thought has gone into this already ... even a little
development ... but I'm afraid that's where it stopped.
http://www.postgis.org/support/wiki/index.php?PostgisTopology
see this thread...
http://postgis.refractions.net/pipermail/postgis-users/2007-October/017532.html
> My thought is you do your edits on the line geometry table and then
> polygon topology is built in a separate (dependent, inherited??) table
> based on the line table using well defined procedures.  The only
> function I  don't see offhand that is not there is a split polygon
> with line.  Just my thoughts.
> Bruce Rindahl
