[postgis-users] Does ST_AsText truncate or round
Paul Ramsey pramsey at cleverelephant.ca
Fri May 16 07:39:17 PDT 2008
It all falls down into this function:
write_double(double val){
        ensure(32);
        if (lwgi)
                sprintf(out_pos,"%.8g",val);
        else
                sprintf(out_pos,"%.15g",val);
        to_end();
On Fri, May 16, 2008 at 3:23 AM, Paragon Corporation <lr at pcorp.us> wrote:
> Slight clarification about what I am trying to solve.
> After edits I am coming back with lines that used to be intersecting no
> longer intersecting and that still have the same AsText representation.
> My hope is to reduce the precision of my geometry in the database so the
> edits don't break the topology of my lines by doing something like this
> Update sometable
>        SET the_geom = ST_SetSRID(ST_AsText(the_geom), mysrid)
> But I fear that if AsText is doing a rounding rather than a truncation, that
> I run the risk of breaking things that used to intersect.  I am more
> concerned about under intersecting than over intersecting.  Although I
> probably haven't thought this out enough so maybe it's a non-issue.
> Thanks,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paragon
> Corporation
> Sent: Friday, May 16, 2008 12:01 AM
> To: 'PostGIS Users Discussion'
> Subject: [postgis-users] Does ST_AsText truncate or round
> Hopefully this is a simple question.  I know that ST_AsText returns a
> geometry that is not necessarily as prescise as what is actually stored in
> the geometry field.  I have an editor that relies on WKT representation.
> Anyrate just wanted to know if the ST_AsText does a rounding of the points
> or it does a truncation of the points.  Also would be nice to know if I
> could control the precision of this since I will need to truncate my actual
> geometry accordingly so that both are in agreement.
> Thanks,
> Regina
> postgis-users mailing list
