[postgis-users] Is GeomUnion() now ST_Union()?
Andy Anderson aanderson at amherst.edu
Fri May 16 07:51:23 PDT 2008
>  select a.gid, geomunion(b.the_geom)
Being new to PostGIS, I've been looking at other people's code
snippets and trying to figure out what they do. I'm a bit mystified
by "geomunion()", though, as it's not in the PostGIS docs, though
there are many references to it in the mailing list archives. Is this
the same as "ST_Union()" <http://postgis.refractions.net/docs/
ch06.html#id2595344>?
I see a statement at the beginning of Chapter 6 that "PostGIS has
begun a transition from the existing naming convention to an SQL-MM-
centric convention. As a result, most of the functions that you know
and love have been renamed using the standard spatial type (ST) prefix."
 From this I can conclude that ST_Union() used to be Union(), and in
that section it says "NOTE: this is renamed from "union" because
union is an SQL reserved word" which implies that even from very
early on it was different than Union(), perhaps GeomUnion(). But if
this is the case, this name change should also be explicitly documented.
If there was a general renaming from Geom* to ST_*, that is also not
documented that I can find.
Confirmation requested, and if necessary documentation for all such
unusual name changes.
Thanks,
-- Andy
