[postgis-users] Does ST_AsText truncate or round
Obe, Regina robe.dnd at cityofboston.gov
Fri May 16 12:33:16 PDT 2008
Paul,
I think you mistook me for a C programmer if you actually thought I
could figure out my answer from this snippet of code :)
First I can't remember what g means.  I remember seeing fs and gs
somewhere before so I can only assume that f means round and g means
truncate?
Secondly what does lwgi stand-for - I can only guess it means
light-weight geom or something along that  - so does that mean that as
far as I'm concerned - .8g is the loop I'm interested in?  Do we even
use non-light weight anymore?
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paul
Ramsey
Sent: Friday, May 16, 2008 10:39 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Does ST_AsText truncate or round
It all falls down into this function:
write_double(double val){
        ensure(32);
        if (lwgi)
                sprintf(out_pos,"%.8g",val);
        else
                sprintf(out_pos,"%.15g",val);
        to_end();
On Fri, May 16, 2008 at 3:23 AM, Paragon Corporation <lr at pcorp.us>
wrote:
> Slight clarification about what I am trying to solve.
> After edits I am coming back with lines that used to be intersecting
no
> longer intersecting and that still have the same AsText
representation.
> My hope is to reduce the precision of my geometry in the database so
the
> edits don't break the topology of my lines by doing something like
this
> Update sometable
>        SET the_geom = ST_SetSRID(ST_AsText(the_geom), mysrid)
> But I fear that if AsText is doing a rounding rather than a
truncation, that
> I run the risk of breaking things that used to intersect.  I am more
> concerned about under intersecting than over intersecting.  Although I
> probably haven't thought this out enough so maybe it's a non-issue.
> Thanks,
> Regina
Paragon
> Corporation
> Sent: Friday, May 16, 2008 12:01 AM
> To: 'PostGIS Users Discussion'
> Subject: [postgis-users] Does ST_AsText truncate or round
> Hopefully this is a simple question.  I know that ST_AsText returns a
> geometry that is not necessarily as prescise as what is actually
stored in
> the geometry field.  I have an editor that relies on WKT
representation.
> Anyrate just wanted to know if the ST_AsText does a rounding of the
points
> or it does a truncation of the points.  Also would be nice to know if
I
> could control the precision of this since I will need to truncate my
actual
> geometry accordingly so that both are in agreement.
> Thanks,
> Regina
> postgis-users mailing list
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
