[postgis-users] I'm missing something
Paul Ramsey pramsey at cleverelephant.ca
Tue May 20 09:51:24 PDT 2008
You don't want the GROUP BY. It is grouping the union op on distinct
geometry... ie, one per row. Remove it and you'll get what you want,
one output row.
P
On Tue, May 20, 2008 at 8:49 AM, Bob Pawley <rjpawley at shaw.ca> wrote:
> Hi
> I am attemptijng to use the ST_Union function to collapse three rows from a
> table called tank_lin into one row in table called process_dgm.
> Here's what I used -
> Insert into graphics.process_dgm(the_geom)
> Select   ST_Union(the_geom)
> from tank_lin
> Group by tank_lin.the_geom;
> The result is three rows inserted into process_dgm, each row appearing to be
> simple copies of each of the original rows.
> I also attempted group by another column but received error 'unknown
> geometry'.
> I also tried STR_LineMerge with similar results.
> What am I not considering?
> Bob
> postgis-users mailing list
