[postgis-users] I'm missing something
Bob Pawley rjpawley at shaw.ca
Tue May 20 10:07:27 PDT 2008
I tried this -
Insert into graphics.process_dgm(the_geom)
 Select   ST_Union(the_geom)
 from tank_lin;
and got the error "Unknown geometry type: 0"
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, May 20, 2008 9:51 AM
Subject: Re: [postgis-users] I'm missing something
> You don't want the GROUP BY. It is grouping the union op on distinct
> geometry... ie, one per row. Remove it and you'll get what you want,
> one output row.
> P
> On Tue, May 20, 2008 at 8:49 AM, Bob Pawley <rjpawley at shaw.ca> wrote:
>> Hi
>> I am attemptijng to use the ST_Union function to collapse three rows from
>> a
>> table called tank_lin into one row in table called process_dgm.
>> Here's what I used -
>> from tank_lin
>> Group by tank_lin.the_geom;
>> The result is three rows inserted into process_dgm, each row appearing to
>> be
>> simple copies of each of the original rows.
>> I also attempted group by another column but received error 'unknown
>> geometry'.
>> I also tried STR_LineMerge with similar results.
>> What am I not considering?
>> Bob
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
