[postgis-users] I'm missing something
Obe, Regina robe.dnd at cityofboston.gov
Tue May 20 10:56:17 PDT 2008
Bob,
Strange. I don't think I have ever seen quite that error before.  What does
SELECT ST_GeometryType(the_geom)
FROM tank_lin;
give you?
Regina
From: postgis-users-bounces at postgis.refractions.net on behalf of Bob Pawley
Sent: Tue 5/20/2008 1:07 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] I'm missing something
I tried this -
Insert into graphics.process_dgm(the_geom)
 Select   ST_Union(the_geom)
 from tank_lin;
and got the error "Unknown geometry type: 0"
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, May 20, 2008 9:51 AM
> You don't want the GROUP BY. It is grouping the union op on distinct
> geometry... ie, one per row. Remove it and you'll get what you want,
> one output row.
> P
> On Tue, May 20, 2008 at 8:49 AM, Bob Pawley <rjpawley at shaw.ca> wrote:
>> Hi
>> I am attemptijng to use the ST_Union function to collapse three rows from
>> a
>> table called tank_lin into one row in table called process_dgm.
>> Here's what I used -
>> from tank_lin
>> Group by tank_lin.the_geom;
>> The result is three rows inserted into process_dgm, each row appearing to
>> be
>> simple copies of each of the original rows.
>> I also attempted group by another column but received error 'unknown
>> geometry'.
>> I also tried STR_LineMerge with similar results.
>> What am I not considering?
>> Bob
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080520/22ebb6b6/attachment.html>
