[postgis-users] I'm missing something
Bob Pawley rjpawley at shaw.ca
Tue May 20 11:11:08 PDT 2008
Re: [postgis-users] I'm missing somethingHi Regina
It gives me three rows each with the expression "ST_MultiLineString" with nothing else.
Bob
  ----- Original Message -----
  To: PostGIS Users Discussion
  Sent: Tuesday, May 20, 2008 10:56 AM
  Subject: RE: [postgis-users] I'm missing something
  Bob,
  Strange. I don't think I have ever seen quite that error before.  What does
  SELECT ST_GeometryType(the_geom)
  FROM tank_lin;
  give you?
  Regina
  From: postgis-users-bounces at postgis.refractions.net on behalf of Bob Pawley
  Sent: Tue 5/20/2008 1:07 PM
  Subject: Re: [postgis-users] I'm missing something
  I tried this -
  Insert into graphics.process_dgm(the_geom)
   Select   ST_Union(the_geom)
   from tank_lin;
  and got the error "Unknown geometry type: 0"
  Bob
  To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
  Sent: Tuesday, May 20, 2008 9:51 AM
  > You don't want the GROUP BY. It is grouping the union op on distinct
  > geometry... ie, one per row. Remove it and you'll get what you want,
  > one output row.
  > P
  > On Tue, May 20, 2008 at 8:49 AM, Bob Pawley <rjpawley at shaw.ca> wrote:
  >> Hi
  >> I am attemptijng to use the ST_Union function to collapse three rows from
  >> a
  >> table called tank_lin into one row in table called process_dgm.
  >> Here's what I used -
  >> from tank_lin
  >> Group by tank_lin.the_geom;
  >> The result is three rows inserted into process_dgm, each row appearing to
  >> be
  >> simple copies of each of the original rows.
  >> I also attempted group by another column but received error 'unknown
  >> geometry'.
  >> I also tried STR_LineMerge with similar results.
  >> What am I not considering?
  >> Bob
  >> postgis-users mailing list
  >> http://postgis.refractions.net/mailman/listinfo/postgis-users
  The substance of this message, including any attachments, may be confidential, legally privileged and/or exempt from disclosure pursuant to Massachusetts law. It is intended solely for the addressee. If you received this in error, please contact the sender and delete the material from any computer.
  Help make the earth a greener place. If at all possible resist printing this email and join us in saving paper.
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080520/e499e1f1/attachment.html>
