[postgis-users] I'm missing something
Paul Ramsey pramsey at cleverelephant.ca
Tue May 20 13:21:04 PDT 2008
Attach the shape file to a bug in the bug tracker and I will have a look.
http://code.google.com/p/postgis/issues/list
P
On Tue, May 20, 2008 at 1:12 PM, Bob Pawley <rjpawley at shaw.ca> wrote:
> They are three lines that, on Quantum GIS, display as a flat U - a simple
> tank. Using either tank_lin or process_dgn tables - exactly what I imported
> using dxf2postgis.
> 'Select as text' returns three rows each with the expression
> "Multilinestrings" followed by brackets and coordinates.
> 'Select St_Union' returns - unknown geometry error.
> Are you thinking there is something wrong with the installation?
> Bob
> ----- Original Message ----- From: "Obe, Regina" <robe.dnd at cityofboston.gov>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Tuesday, May 20, 2008 11:51 AM
> Subject: RE: [postgis-users] I'm missing something
> Are these big geometries?  What does
> SELECT ST_AsText(the_geom)
>   FROM tank_lin;
> Also just to rule out its the table you are inserting into  - does the
> Union without inserting work?
> Select   ST_Union(the_geom)
> from tank_lin;
> ________________________________
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
> Pawley
> Sent: Tuesday, May 20, 2008 2:11 PM
> To: PostGIS Users Discussion
> Subject: Re: [postgis-users] I'm missing something
> Hi Regina
> It gives me three rows each with the expression "ST_MultiLineString"
> with nothing else.
> Bob
> ----- Original Message ----- From: Obe, Regina
> <mailto:robe.dnd at cityofboston.gov>
> <mailto:postgis-users at postgis.refractions.net>
> Sent: Tuesday, May 20, 2008 10:56 AM
> Bob,
> Strange. I don't think I have ever seen quite that error before.
> What does
> SELECT ST_GeometryType(the_geom)
> FROM tank_lin;
> give you?
> Regina
> From: postgis-users-bounces at postgis.refractions.net on behalf of
> Bob Pawley
> Sent: Tue 5/20/2008 1:07 PM
> I tried this -
> Insert into graphics.process_dgm(the_geom)
> from tank_lin;
> and got the error "Unknown geometry type: 0"
> Bob
> From: "Paul Ramsey" <pramsey at cleverelephant.ca>
> Sent: Tuesday, May 20, 2008 9:51 AM
>> You don't want the GROUP BY. It is grouping the union op on
> distinct
>> geometry... ie, one per row. Remove it and you'll get what you
> want,
>> one output row.
>> P
>> On Tue, May 20, 2008 at 8:49 AM, Bob Pawley <rjpawley at shaw.ca>
> wrote:
>>> Hi
>>> I am attemptijng to use the ST_Union function to collapse
> three rows from
>>> a
>>> table called tank_lin into one row in table called
> process_dgm.
>>> Here's what I used -
>>> from tank_lin
>>> Group by tank_lin.the_geom;
>>> The result is three rows inserted into process_dgm, each row
> appearing to
>>> be
>>> simple copies of each of the original rows.
>>> I also attempted group by another column but received error
> 'unknown
>>> geometry'.
>>> I also tried STR_LineMerge with similar results.
>>> What am I not considering?
>>> Bob
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
> The substance of this message, including any
> attachments, may be confidential, legally privileged and/or exempt from
> disclosure pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender and
> delete the material from any computer.
> Help make the earth a greener place. If at all possible
> resist printing this email and join us in saving paper.
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
