[postgis-users] I'm missing something
Bob Pawley rjpawley at shaw.ca
Tue May 20 14:12:07 PDT 2008
Returns
POSTGIS="1.3.2" GEOS="3.0.0rc4-CAPI-1.3.3"PROJ='Rel.4.5.0, 22 Oct 2006" USE
STATS
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Tuesday, May 20, 2008 2:03 PM
Subject: RE: [postgis-users] I'm missing something
Bob,
works fine for me and gives
MULTILINESTRING((80 34.25,80 60),(46 34.25,80 34.25),(46 60,46 34.25))
or binary
010500000003000000010200000002000000000000000000544000000000002041400000
0000000054400000000000004E4001020000000200000000000000000047400000000000
204140000000000000544000000000002041400102000000020000000000000000004740
0000000000004E4000000000000047400000000000204140
What does your
SELECT postgis_full_version();
return
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Bob
Pawley
Sent: Tuesday, May 20, 2008 4:44 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] I'm missing something
I've attached an sql dump of the table tank_lin.
Hope this helps.
Bob
Sent: Tuesday, May 20, 2008 1:21 PM
> Attach the shape file to a bug in the bug tracker and I will have a
look.
> http://code.google.com/p/postgis/issues/list
> P
> On Tue, May 20, 2008 at 1:12 PM, Bob Pawley <rjpawley at shaw.ca> wrote:
>> They are three lines that, on Quantum GIS, display as a flat U - a
simple
>> tank. Using either tank_lin or process_dgn tables - exactly what I
>> imported
>> using dxf2postgis.
>> 'Select as text' returns three rows each with the expression
>> "Multilinestrings" followed by brackets and coordinates.
>> 'Select St_Union' returns - unknown geometry error.
>> Are you thinking there is something wrong with the installation?
>> Bob
>> ----- Original Message ----- From: "Obe, Regina"
>> <robe.dnd at cityofboston.gov>
>> Sent: Tuesday, May 20, 2008 11:51 AM
>> Are these big geometries?  What does
>> SELECT ST_AsText(the_geom)
>>   FROM tank_lin;
>> Also just to rule out its the table you are inserting into  - does
the
>> Union without inserting work?
>> Select   ST_Union(the_geom)
>> from tank_lin;
>> ________________________________
Bob
>> Pawley
>> Sent: Tuesday, May 20, 2008 2:11 PM
>> Hi Regina
>> It gives me three rows each with the expression "ST_MultiLineString"
>> with nothing else.
>> Bob
>> ----- Original Message ----- From: Obe, Regina
>> <mailto:robe.dnd at cityofboston.gov>
>> <mailto:postgis-users at postgis.refractions.net>
>> Sent: Tuesday, May 20, 2008 10:56 AM
>> Bob,
>> Strange. I don't think I have ever seen quite that error before.
>> What does
>> SELECT ST_GeometryType(the_geom)
>> FROM tank_lin;
>> give you?
>> Regina
>> From: postgis-users-bounces at postgis.refractions.net on behalf of
>> Bob Pawley
>> Sent: Tue 5/20/2008 1:07 PM
>> I tried this -
>> Insert into graphics.process_dgm(the_geom)
>> from tank_lin;
>> and got the error "Unknown geometry type: 0"
>> Bob
>> From: "Paul Ramsey" <pramsey at cleverelephant.ca>
>> Sent: Tuesday, May 20, 2008 9:51 AM
>>> You don't want the GROUP BY. It is grouping the union op on
>> distinct
>>> geometry... ie, one per row. Remove it and you'll get what you
>> want,
>>> one output row.
>>> P
>>> On Tue, May 20, 2008 at 8:49 AM, Bob Pawley <rjpawley at shaw.ca>
>> wrote:
>>>> Hi
>>>> I am attemptijng to use the ST_Union function to collapse
>> three rows from
>>>> a
>>>> table called tank_lin into one row in table called
>> process_dgm.
>>>> Here's what I used -
>>>> from tank_lin
>>>> Group by tank_lin.the_geom;
>>>> The result is three rows inserted into process_dgm, each row
>> appearing to
>>>> be
>>>> simple copies of each of the original rows.
>>>> I also attempted group by another column but received error
>> 'unknown
>>>> geometry'.
>>>> I also tried STR_LineMerge with similar results.
>>>> What am I not considering?
>>>> Bob
>>>> _______________________________________________
>>>> postgis-users mailing list
>>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> The substance of this message, including any
>> attachments, may be confidential, legally privileged and/or exempt
from
>> disclosure pursuant to Massachusetts law. It is intended solely for
the
>> addressee. If you received this in error, please contact the sender
and
>> delete the material from any computer.
>> Help make the earth a greener place. If at all possible
>> resist printing this email and join us in saving paper.
>> The substance of this message, including any attachments, may be
>> confidential, legally privileged and/or exempt from disclosure
>> solely for the addressee. If you received this in error, please
>> contact the sender and delete the material from any computer.
