[postgis-users] Splitting a Polygon with a Linestring
Chris Hermansen chris.hermansen at timberline.ca
Wed May 21 14:58:48 PDT 2008
"Some day I hope to get this into JTS/GEOS"...
Go, Martin, go!
Martin Davis wrote:
> That should work.  You may also have the problem of determining which
> of the resultant polygons fell on each side of the drawn line.  The
> usual way to do this would be to run some point-in-polygon queries.
> It's amazing how much this use case comes in many different venues
> (PostGIS, GUI tools, etc).  Some day I hope to get this into JTS/GEOS
> as a provided operation, at which point this will be much easier to
> accomplish.
> James Beaudoin wrote:
>> I think the steps below will work but I have one question. I am
>> creating an application that allows a user to split a polygon by
>> drawing a linestring across the polygon they wish to change. The
>> crossing linestring has parts that are outside the polygon and I want
>> to remove that before I geomunion. What's the easiest way to do that?
>> - extract the lines that make up the polygon
>> - add to this your crossing linestring
>> - geomunion the lines together.
>> - polygonize the union-ed set
>> Thanks,
>> Jim
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
