[postgis-users] Float 8
Chris Hermansen chris.hermansen at timberline.ca
Thu May 22 14:45:23 PDT 2008
Hmm, the form it takes?  Not sure I understand you.  Let me try
nevertheless.
A float8 is a single number.  It's 64 bits of floating point, part of
which is exponent and part of which is mantissa.  The exponent is
understood as a power of two.  The most common double precision floating
point representation in use today represents numbers to about 14 digits
of accuracy in the range of 10^-308 to 10^308, negative and positive.
There are other special numbers like ± infinity and NaN (not a number).
Most computers use the IEEE 754-1985 standard for floating point.  You
can read all about this at http://en.wikipedia.org/wiki/IEEE_floating_point
A concrete example of a float8 number is 1.4976931341623151×10^3
What you are looking at specifically -
ST_Translate(geometry,float8,float8,float8) - takes a given geometry and
"translates" (ie moves relative to the origin) by the three float8
offset values you provide.  You might think of this as a shift.
Let's say you called ST_Translate() on a point (x,y,z) with offset
values (a,b,c).  Then your translated coordinates would be:
x' = x + a
y' = y + b
z' = z + c
ST_Translate() is one of the three components of an affine
transformation, the other two being ST_Scale() and ST_RotateZ().
Does this help?
Bob Pawley wrote:
> Any suggestions on the form it takes (integer, cooridinate, binary)
> and how it is used with ST_Translate???
> Bob
> ----- Original Message ----- From: "Chris Hermansen"
> <chris.hermansen at timberline.ca>
> To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Sent: Thursday, May 22, 2008 1:48 PM
> Subject: Re: [postgis-users] Float 8
>> float8 is double precision, about 14 digits of precision to be precise
>> :-) plus a bigger allowable exponent than float4 or single precision.
>> Bob Pawley wrote:
>>> Hi
>>> Would someone please tell me what is meant by float 8 in this
>>> function? I know they refere to x, y and z coordinates. (An example
>>> would help)
>>> ST_Translate(geometry, float8, float8, float8)
>>> Bob
>>> postgis-users mailing list
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
>> Regards,
>> Chris Hermansen         mailto:chris.hermansen at timberline.ca
>> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
>> Timberline Natural Resource Group · http://www.timberline.ca
>> 401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
Regards,
