[postgis-users] PostgreSQL/PostGIS and ArcGIS Server 9.3
Clay, Bruce bclay at ball.com
Fri May 23 11:56:03 PDT 2008
Any chance that PostGres/PostGis will work with ArcSDE Personal Edition?
Bruce
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Tim
Bowden
Sent: Friday, May 23, 2008 2:44 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] PostgreSQL/PostGIS and ArcGIS Server 9.3
On Fri, 2008-05-23 at 11:13 -0700, Paul Ramsey wrote:
> On Fri, May 23, 2008 at 11:05 AM, Tim Bowden
<tim.bowden at westnet.com.au> wrote:
> >> In general, if you restrict yourself ot reading with 3rd party
tools
> >> and writing with ESRI tools, or non-ESRI tools working through the
SDE
> >> API, you should be safe.
> > So how much of the API is published?  My (very limited)
understanding is
> > that it's not quite simple, but how complex can it really be to
> > implement an abstraction layer that allows open source clients to
act
> > like ArcGIS clients (full read/write)?
> The SDE client API all published, and Geotools in particular has
> worked on having a pretty complete support for it. Recent work has
> even been looking at supported versioned edits to SDE in Geotools.
> Unversioned edits have been supported for some time.  The only hidden,
> non-technical, downside is that the SDE license manager only allows 5
> non-ESRI clients to connect by default, so you have to be judicious in
> what you connect to the server.
> P
Well that maybe opens up the possibilities.  Call me a dreamer if you
want but what if you could do multi-master between a PostgreSQL/PostGIS
and SDE (on anything) using two stage commit with geotools as the basis
of a piece of middleware managing the connections.  Put
update/insert/delete triggers in both SDE/whatever and
PostgreSQL/PostGIS that call the "multi-master" middleware and all of a
sudden (well, after appropriate non trivial dev work) you've broken the
strangle hold of the SDE engine on your enterprise.  There would be
issues mapping data types (spatial and non-spatial) with different
definitions between the systems which would need to be managed.  I
imagine you can shoot this idea down fairly easily, but at least you'll
increase my understanding in doing so :-)
Regards,
Tim
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
This message and any enclosures are intended only for the addressee.  Please
notify the sender by email if you are not the intended recipient.  If you are
not the intended recipient, you may not use, copy, disclose, or distribute this
message or its contents or enclosures to any other person and any such actions
may be unlawful.  Ball reserves the right to monitor and review all messages
and enclosures sent to or from this email address.
