[postgis-users] srid
Bob Pawley rjpawley at shaw.ca
Mon May 26 11:13:24 PDT 2008
I think I have the spatial_ref_table with a couple of rows that should be
recognized by the ST_Transform function.
However, I now get the error "Input geometry has unknown (-1) srid".
Does anyone have a thought on how to overcome this? Is this error realing
telling me that the function still doesn't recognize the srid?
Bob
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Sunday, May 25, 2008 11:20 AM
Subject: Re: [postgis-users] srid
> SRID is an index into the table of datums/projections/coordinate  systems
> that PostGIS maintains; the commands to create that table are  in the file
> spatial_ref_sys.sql that comes with the distribution.
> If you want to build your own transformation, you could start with one  of
> the listed INSERT statements that matches the type of projection,  and
> change the coordinates to match your interest. Then add it to the
> existing table with an SRID that isn't being used.
> By the way, the SRID is part of the EPSG standard
> <http://en.wikipedia.org/wiki/SRID
> >, so keep that in mind for future potential conflicts.
> -- Andy
> On May 25, 2008, at 12:21 PM, Bob Pawley wrote:
>> Hi
>> I am attempting to learn Postgis to use as a geometric tool rather  than
>> a geographic tool.
>> The function ST_Transform(geometry, integer)  seems to be  potentially
>> quite useful.
>> Apparently, the integer required is the new coordinates referenced  by
>> the srid. Is there some way of building a spatail reference table  in
>> which I can enter my coordinates that the ST_Transform function  will
>> recognize. My first simplistic attempt (entering a coordinate  with an
>> id) didn't work.
>> Bob
>> postgis-users mailing list
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
