[postgis-users] Re: shp2pgsql (was "asKML")
Andy Anderson aanderson at amherst.edu
Tue May 27 13:23:56 PDT 2008
Sorry, that subject line should have been "shp2pgsql". That question
will come later, I'm sure! :-)
On May 27, 2008, at 4:20 PM, Andy Anderson wrote:
> I've been working around one minor issue and it occurred to me that
> someone here might be able to explain the rationale for its design.
> I start with a shapefile of US states, which to me appears to be a
> set of multipolygons, one for each state. So, for example, Hawaii is
> a single multipolygon containing 27 polygons (at this scale).
> I then use shp2pgsql to produce a table of polygons, and Hawaii ends
> up as 27 multipolygons each containing one polygon!
> Is there a good reason for this? Or do I have a misconception about
> how Hawaii is being stored in the shapefile?
> Thanks,
> -- Andy
