[postgis-users] Attributes update
Paragon Corporation lr at pcorp.us
Sat May 31 05:34:12 PDT 2008
I think you are right.  That's what I get for copying other peoples code
assuming it was doing the right thing and reformatting it.
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Andy
Anderson
Sent: Friday, May 30, 2008 9:50 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Attributes update
I think what Lucas wants is actually the mirror statement:
UPDATE parcels SET landuse = land_use.type FROM landuse WHERE
ST_Within(centroid(parcels.the_geom),land_use.the_geom);
-- Andy
On May 30, 2008, at 7:54 AM, Obe, Regina wrote:
> Markus,
> Rule of thumb for relation operations - I think you always read it  A
> function_name B
> So A within B -> Within(A,B)
> I think that holds true for all the spatial relation functions in
> PostGIS.
> Lucas - Markus gave you the correlated sub query approach.  You can
> also do it without a subquery.  Which one is faster depends on how big
> your data sets are I think.  The non-correlated I think generally
> works better (especially for large data sets) (make sure to have
> indexes on both geom fields).
> I think the correlated sub query always forces a nested loop join.
> Below is a non-sub query way of doing it.  For the new versions of
> PostGIS you can also replace the && Within with just ST_Within.
> UPDATE land_use SET type = parcels.landuse FROM parcels WHERE
> Hope that helps,
> Regina
> Markus Schaber
> Sent: Friday, May 30, 2008 7:26 AM
> To: postgis-users at postgis.refractions.net
> Hi, Lucas,
> "Lucas Mueller" <lucas.mueller at gmail.com> wrote:
>> I have two polygon layers (let's say Parcels and Land_use). I would
> like to
>> assign the attribute Land_use.type to the Parcels.landuse column by a
> query
>> that assigns a certain land use type to a parcel if the centroid of
> the
>> parcel is within a certain land use polygon. I hope to be clear
> enough...
>> Any idea on how to proceed?
> Try something like:
> update land_use set type=(select parcels.landuse FROM parcels where
> land_use.the_geom && parcels.the_geom AND
> within(centroid(parcels.the_geom),land_use.the_geom));
> Btw, I tend to mix up the argument order of within and contains, so
> please double-check.
> Regards,
> Markus
> Markus Schaber | Logical Tracking&Tracing International AG
> Dipl. Inf.     | Software Development GIS
> Fight against software patents in Europe! www.ffii.org
> www.nosoftwarepatents.org
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended solely for the
> addressee. If you received this in error, please contact the sender
> and delete the material from any computer.
