[postgis-users] Union, but need to exclude any void
Toby Rainthorpe toby.rainthorpe at frsltd.co.uk
Sat Nov 1 16:52:10 PDT 2008
I can confirm that the union does work correctly. My problem comes
from using the google maps api to represent the data. As far as I can
tell google maps polygons cannot have void / inner boundary. I think
the only way to create the void is to find the minimum number of
polygons that can make up the polygon with the void, but not include it.
For instance looking a 5 x 5 grid with two voids I could use a minimum
of two polygons to create the illusion of the void.
1 = Polygon 1
2 = Polygon 2
x = Void
1	1	1	2	2
1	1	1	X	2
1	X	2	2	2
1	1	1	1	1
1	1	1	1	1
You can use a KML file, however there are size restrictions. You can
also use collect and render all the polygons to get the desired
effect, however this is inefficient and becomes harder to style
correctly.
Does anyone know if a open layers, mapserver, geo server etc. setup
would be able to deal with voids / inner boundaries of polygons
directly. Or any other ideas of getting around this issue with the
google maps api?
Thanks for your help,
Toby
