[postgis-users] pgsql2shp problem
Mark Cave-Ayland mark.cave-ayland at siriusit.co.uk
Wed Nov 5 07:28:11 PST 2008
Murray Richardson wrote:
> Hello postgis users,
> I frequently have a problem when running the pgsql2shp dumper whereby
> the program is executed but it does not actually  complete.  It only
> creates an empty shapefile.  The Dumping output  indicates only a single
> "X", as shown below:
> C:\Program Files\PostgreSQL\8.3\bin>pgsql2shp -u postgres -P creemore -f
> V:\Lida
> rData\utm17_3.shp spatialDB bare_earth_utm17
> Initializing... Done (postgis major version: 1).
> Output shape: Point
> Dumping: X
> This results in an empty shapefile.
> Often, the execution works properly on the second or third attempt.  In
> general this is not a problem except when I need to run it
> programmatically, in which case I need a more reliable execution.
> Any ideas?
Not sure, as a single X doesn't really give much in the way of debugging
information :(  Some PostgreSQL on Windows users have reported problems
with 3rd party firewalls and/or virus checkers interfering with normal
operation - it may be worth trying to disable these temporarily and
trying again.
HTH,
Mark.
Mark Cave-Ayland
Sirius Corporation - The Open Source Experts
http://www.siriusit.co.uk
T: +44 870 608 0063
