[postgis-users] shp2pgsql question
Nandorov nandorov at gmail.com
Fri Nov 7 12:26:26 PST 2008
Dana:
inside your postgis bin directory you have to run:
shp2pgsql [options] [shape file] [schema][table] | psql [database]
for example:
shp2pgsql C:\shp\myshape.shp public.test_shp | psql mydatabase
maybe it will be more helpfull:
http://postgis.refractions.net/documentation/manual-1.3/ch04.html#id2868133
Hope it helps,
Regards
Dana Lee wrote:
> Hi,
> I'm new to PostGIS and am having troubles running shp2pgsql. When I run
> the
> command below nothing happens, there is not Jordyn.sql file in my C drive.
> I've copied the shp2pgsql.exe and shapefile to my C drive and changed my
> current directory to my C drive, then tried running the command with and
> without the c:/ but nothing ever happens. I'm not sure what I'm doing
> wrong.
> Any help or advice would be greatly appreciated. Thanks.
> c:/shp2pgsql -s 26912 -p c:/Jordyn Jordyn > c:/Jordyn.sql
> Dana
> postgis-users mailing list
View this message in context: http://www.nabble.com/shp2pgsql-question-tp20387316p20388273.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
