[postgis-users] PostGIS 1.3.4 RC3 released
Tim Bowden tim.bowden at westnet.com.au
Fri Nov 21 05:50:06 PST 2008
On Fri, 2008-11-21 at 12:25 +0000, Mark Cave-Ayland wrote:
> Tim Bowden wrote:
> > On Fri, 2008-11-21 at 00:42 +0900, Tim Bowden wrote:
> >> Debian etch, AMD64 dual core
> >> gcc (GCC) 4.1.2 20061115 (prerelease) (Debian 4.1.1-21)
> >> postgresql 8.1.15
> >> postgis 1.3.4rc3
> >> geos 2.2.3, 3.0.3 & 3.1 all make and install fine.  Tested all with
> >> importing a shp file using shp2psql no probs.
> > Rather postgis 1.3.4rc3 makes and installs fine with each geos.  Too
> > late at night.
> > Regards,
> > Tim
> Thanks Tim. One quick thing to check is whether "make check" completes
> with no failures on all of the above, as this is a good indicator of
> whether things are working.
> Incidentally I submitted some patches for GEOS 2.2 branch, so at least
> now I have a way of testing them against my system here.
postgis 1.3.4rc3 with:
geos 2.2.3 make check no failures:
Run tests: 38
Failed: 0
geos 3.0.3 make check no failures:
Run tests: 39
Failed: 0
geos 1.3 make check resulted in 1 fail:
regress_ogc_prep. failed (diff expected
obtained: /tmp/pgis_reg_15519/test_38_diff)
Run tests: 40
Failed: 1
Regards,
Tim
> ATB,
> Mark.
Experience is that marvelous thing that enables you recognize a mistake
when you make it again.
