[postgis-users] Get concave hull from an array of longitude inlatitude points
Martin Davis mbdavis at refractions.net
Mon Nov 24 12:01:53 PST 2008
Another approach is here:
http://www.fmepedia.com/index.php/Concave_Hull_Creator_Workspace
This looks like it builds a Delaunay TIN on the pointset, discards any
edges longer than a given tolerance, polygonizes the remaining edges,
and then merges all polygons.  This seems like it would be faster than
the approach on the Grass wiki.  It also has the nice property that
every vertex of the result is an input point.
Fascinating!
Martin Davis wrote:
> Yeah, I saw that too.  Unfortunately the algorithm is only available
> by email, and is implemented in Mathematica.   It also sounds somewhat
> complex.
> But I guess this sort of answers my question - there are algorithms
> which people have called "concave hull", and they produce concave
> polygons from sets of points in some kind of way.  I don't think
> there's any consensus on what algorithm to use, though.
> One interesting approach is here:
> http://grass.osgeo.org/wiki/Create_concave_hull
> In any case, obviously this isn't in PostGIS right now.
> Obe, Regina wrote:
>> Evidentally its this thing
>> http://ubicomp.algoritmi.uminho.pt/local/concavehull.html
>> So I guess basically you take the boundary and you get rid of points
>> that have points sitting to the right/left/top/or bottom of it and then
>> you form a polygon from the remaining points.
>> Well at least that is what it seems like to me visually.  Just not
>> quite sure how to program such a thing without writing yuck
>> procedural code.
>> Hope that helps,
>> Regina
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
