[postgis-users] degree vs. metric projection performance?
Picavet Vincent Vincent.Picavet at mediapost.fr
Wed Nov 26 06:25:40 PST 2008
The google mercator projection, called EPSG:900913 as <google> in
1337-speech, is now referenced as EPSG 3785 :
http://www.epsg-registry.org/report.htm?type=lastQuery&title=&reportDeta
il=short&style=urn:uuid:report-style:default-with-code&style_name=OGP%20
Default%20With%20Code&title=3785
You will find definitions in all formats here :
http://spatialreference.org/ref/user/popular-visualisation-crs-mercator/
Especially for postgis :
postgis/
Bye,
Vincent
> >  By the way, are the Google Mercator and WGS84 systems equivalent
> No they aren't.  I think Google is a mercator meter
> projection (not good for measurement though but more or less
> good for presentation) and they use WGS84 datum when
> accepting data.  I think it actually has an official SRID
> (could be wrong) that is EPSG:900913
> and proj4 looks like this
> +proj=merc +a=6378137 +b=6378137 +lat_ts=0.0 +lon_0=0.0
> +x_0=0.0 +y_0=0
> +k=1.0 +units=m +nadgrids=@null +no_defs
> People usually plot WGS84 longlat (4326) on Google Maps, thus
> the confusion.
> postgis-users mailing list
> The substance of this message, including any attachments, may
> be confidential, legally privileged and/or exempt from
> disclosure pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error,
> please contact the sender and delete the material from any computer.
