[postgis-users] ST_UNION(linestring, linestring) returns a multilinestring
Stephen Woodbridge woodbri at swoodbridge.com
Tue Oct 7 20:10:11 PDT 2008
Dane,
Thanks, that worked great.
-Steve
Dane Springmeyer wrote:
> Stephen,
> Try:
> select astext(st_linemerge(ST_Collect(b.the_geom)))
>  from (
>    select ST_GeomFromText('LINESTRING(35.5269251710001
> 33.891749555,35.527091166 33.8917984710001)') as the_geom
>   union
>   select ST_GeomFromText('LINESTRING(35.527091166
> 33.8917984710001,35.5274352000001 33.8918998510001,35.528236559
> 33.8919810230001)') as the_geom
>  ) as b;
> Thanks works for me.
> Dane
> On Oct 7, 2008, at 2:38 PM, Stephen Woodbridge wrote:
>> This does not seem to work. Am I using it wrong?
>> select astext(st_linemerge(b.the_geom))
>>  from (
>>   union
>>  ) as b;
>>                                                  astext
>> LINESTRING(35.5269251710001 33.891749555,35.527091166 33.8917984710001)
>> LINESTRING(35.527091166 33.8917984710001,35.5274352000001
>> 33.8918998510001,35.528236559 33.8919810230001)
>> (2 rows)
>> The results that I am expecting to get are:
>> 33.8919810230001)
>> -Steve
>> Fred Lehodey wrote:
>>> =>   ST_LineMerge()
>>> Fred.
>>> On Tue, Oct 7, 2008 at 8:58 PM, David William Bitner
>>> <bitner at gyttja.org <mailto:bitner at gyttja.org>> wrote:
>>>    Check out ST_Merge()
>>>    On Tue, Oct 7, 2008 at 3:54 PM, Stephen Woodbridge
>>>    <woodbri at swoodbridge.com <mailto:woodbri at swoodbridge.com>> wrote:
>>>        Hi all,
>>>        This is very annoying. I have two linestrings the join
>>>        end-to-end and I want to build a new single linestring by
>>>        merging the two. How can I do this?
>>>        Thanks,
>>>         -Steve
>>>        select astext( ST_Union(
>>>        33.891749555,35.527091166 33.8917984710001)'),
>>>        33.8919810230001)')                                    ));
>>>                     astext
>>>         MULTILINESTRING((35.5269251710001 33.891749555,35.527091166
>>>        33.8917984710001),(35.527091166
>>>        33.8919810230001))
>>>        (1 row)
>>>        _______________________________________________
>>>        postgis-users mailing list
>>>        postgis-users at postgis.refractions.net
>>>        <mailto:postgis-users at postgis.refractions.net>
>>>        http://postgis.refractions.net/mailman/listinfo/postgis-users
