[postgis-users] ESRI 9.3 & PostGIS
Obe, Regina robe.dnd at cityofboston.gov
Thu Oct 9 09:29:22 PDT 2008
Mark,
Based on talking with people and reading their experiences, I think to
use even the PostGIS geometry using ESRI's ArcGIS desktop support
you need to have an ArcGIS server license similar to if you wanted to
use Oracle Spatial SDE or SQL Server (minus express). But you can have
the service turned
off if you are just using the PostGIS geometry according to Dave
Bouman's note, so then I'm not quite sure what you are paying for if you
have to pay.
I get the impression just the additional functions that ArcGIS installs
into PostgreSQL to allow ArcGIS desktop to talk to PostGIS/PostgreSQL.
I think they took away the direct connect thingy they use to have or
rather you have to pay for it now under the umbrella of ArcSDE.  I could
be wrong though.  All that licensing stuff is very confusing and  I've
been too busy with other things (like statistical analyse of data) to be
bothered with figuring out how ArcGIS works or is licensed.
I could be wrong though, but that's the impression I have gotten.
If you use something like ZigGIS, that works purely using ArcGIS apis
and doesn't rely on SDE or the functions ESRI installs and will work for
9.1+ but then you are paying for per desktop instance install as opposed
to a server install.
Well maybe somebody who actually knows something will chime in :).
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
MarkW
Sent: Thursday, October 09, 2008 12:11 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ESRI 9.3 & PostGIS
Thanks for setting up that page on the wiki - that's a help.
I have some very basic questions, from the perspective of a non-ArcSDE
user. I understand the zigGis and QGIS, etc options, but having just
installed Arc9.3, I hoped to view/edit PostGIS data via ArcMap. I
think what I want is closest to Paolo's scenario #3:
http://www.paolocorti.net/2008/06/06/spatial-database-for-postgres-and-a
rcgis-users-how-to-choose/
I have read various posts indicating that if I want to access PostGIS
data at all in ArcMap, I should be running (ArcGIS server and ?)
ArcSDE. I cannot easily separate the help on using Postgres SDE vs
PostGIS; it sounds, first of all, that either requires Postgres ArcSDE
be installed, and that my spatial data be in a database called "sde".
Correct? I've only been reading through the help for an hour or two,
so I may have missed something.
All the help at ESRI on PostGIS data is under the ArcGisServer help -
do I also have to run ArcGIS server, or is it just listed there
because that's the main target audience/intended use?
Thanks in advance,
Mark
On Wed, Oct 8, 2008 at 7:02 PM, Paragon Corporation <lr at pcorp.us> wrote:
> Since this seems to be a very popular topic, I have posted the links I
know
> about to the wiki
> http://postgis.refractions.net/support/wiki/index.php?Postgisarcgis
> Anyone who comes up with more war/love stories, please feel free to
put your
> links on the above page.
> Its linked from the front
> http://postgis.refractions.net/support/wiki/ (under PostGIS and
> ArcSDE/ArcGIS 9.3 Articles)
> Hope that helps,
> Regina
Paragon
> Corporation
> Sent: Wednesday, October 08, 2008 6:45 PM
> To: 'PostGIS Users Discussion'
> Subject: RE: [postgis-users] ESRI 9.3 & PostGIS
> Brent,
> Sorry I haven't tried this yet either.  I still find the whole ArcGIS
9.3
> environment a bit daunting to deal with, but if you haven't looked at
other
> people's documentation of their experiences, you should take a gander.
> >From readings of blogs I gather you have the choice of making your
self
> inextricably married to ESRI via their PostSDE ST_Geometry
implementation or
> just chummy chummy using the  PostGIS geometry.  Benefits of PostSDE
> presumably you can take advantage of more of the versioning
functionality in
> ArcSDE if that is important to you but lose ability to use these in a
> non-ESRI SDE FOSS aware tool.
> Anyrate I'm sure I posted these links before but can't find the post
now, so
> let me see if I remember from memory and then maybe I'll or someone
else
> will post these to the wiki for easier retrieval.
> 1) Bill Dollins has a great series on using ArcSDE 9.3 with
> PostGIS/PostgreSQL
http://geobabble.wordpress.com/2008/05/28/using-arcsde-93-with-postgresq
l-pa
> rt-1/
http://geobabble.wordpress.com/2008/06/02/using-arcsde-93-with-postgresq
l-pa
> rt-2/
http://geobabble.wordpress.com/2008/07/01/using-arcsde-93-with-postgresq
l-pa
> rt-3/
http://geobabble.wordpress.com/2008/08/21/using-arcsde-93-with-postgresq
l-pa
> rt-35/
> 2) QUICK NOTES
l-pa
> rt-1/
http://geobabble.wordpress.com/2008/03/18/postgresql-support-in-arcgis/
> 3) Paolo Corti has some good stuff too
rcgi
>  Dave Bouman
> 4)
http://blog.davebouwman.net/2008/05/12/PostGISRound2ReadingTheManual.asp
x
>  Hope that helps,
> Regina
Brent
> Wood
> Sent: Wednesday, October 08, 2008 4:29 PM
> Subject: [postgis-users] ESRI 9.3 & PostGIS
> The institute I work for is a long term ESRI user, while I've been
> encouraging the use of FOSS GIS solutions for some years, with growing
> success.
> We are looking at replacing our Arc/Oracle setup with Arc/PostGIS when
we
> upgrade to 9.3 and I'm interested in any experiences anyone may have
with
> this.
> We are hoping that an Arc PostGIS geodtabase can be managed via Arc,
but
> have the contents available as normal (read-only) PostGIS tables, etc
via
> PostGIS client apps such as Geoserver, Mapserver, uDIG, QGIS, gvSIG,
R-GDAL,
> etc.
> Has anyone here had any experience with PostGIS as a 9.3 Geodatabase
and how
> open the data is in these, or whether the geodatabase is inherently
tied up
> with non-standard structures that don't work well with typical PostGIS
> clients?
> Thanks,
>   Brent Wood
> postgis-users mailing list
The substance of this message, including any attachments, may be
confidential, legally privileged and/or exempt from disclosure
pursuant to Massachusetts law. It is intended
solely for the addressee. If you received this in error, please
contact the sender and delete the material from any computer.
