[postgis-users] TRANSFORM failures with some multiploygons - datasample attached
cyw at dls.net cyw at dls.net
Thu Oct 9 21:04:58 PDT 2008
See attached. I viewed it fom PgAdmin UI.  Did the queries you suggested,
the_geom was not NULL.
The sql below returns nothing:
              select gid, the_geom from city where the_geom is null;
The sql below returns npoints = 218:
    select gid, npoints(the_geom) from city where polygon_id=35665106;
Thanks,
CYW
----- Original Message -----
To: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
Sent: Thursday, October 09, 2008 10:12 PM
Subject: Re: [postgis-users] TRANSFORM failures with some multiploygons -
datasample attached
>>> It ran without any error. But some of the resulted values in the_geom
>>> column became null or empty.
> How did you check this?
> select gid from thetable where the_geom is null?
> select gid from thetabel where npoints(the_geom) =
> P
> postgis-users mailing list
Type: application/msword
Desc: not available
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20081009/f6cab351/attachment.doc>
