[postgis-users] PostGIS 1.3.3 on Solaris 10
eroussel eroussel_register at mac.com
Mon Oct 13 14:37:20 PDT 2008
Yes I did:
$ /opt/postgresql/bin/createlang plpgsql testspatialdb
createlang: language "plpgsql" is already installed in database
"testspatialdb"
I'm actually following the procedure from the PostGIS documentation.
Chris Hermansen wrote:
> Aside from compiling PostGIS, have you spatially enabled your database,
> as per
> http://www.postgis.org/documentation/manual-1.3/ch02.html#PGInstall
> ie
> # createlang plpgsql [yourdatabase]
> # psql -d [yourdatabase] -f lwpostgis.sql
> # psql -d [yourdatabase] -f spatial_ref_sys.sql
> eroussel wrote:
>> I currently have a problem with PostGIS 1.3.3 on Solaris 10.
>> PostGIS compiled without problems, however, when I try to run:
>> # /opt/postgresql/bin/psql -d testspatialdb -f
>> /opt/postgresql/share/lwpostgis.sql
>> I get this:
>> psql:/opt/postgresql/share/lwpostgis.sql:53: NOTICE:  type "histogram2d"
>> is
>> not yet defined
>> DETAIL:  Creating a shell type definition.
>> psql:/opt/postgresql/share/lwpostgis.sql:53: ERROR:  could not load
>> library
>> "/opt/postgresql/lib/liblwgeom.so": ld.so.1: postgres: fatal: libc.so.6:
>> open failed: No such file or directory
>> Looking at liblwgeom.so I get this:
>> $ ldd liblwgeom.so
>>         libgeos_c.so.1 =>        /opt/geos/lib/libgeos_c.so.1
>>         libproj.so.0 =>  /opt/proj/lib/libproj.so.0
>>         libc.so.6 =>     (file not found)
>>         libgeos-3.0.0.so =>      /opt/geos/lib/libgeos-3.0.0.so
>>         libstdc++.so.6 =>        /usr/sfw/lib/libstdc++.so.6
>>         libm.so.2 =>     /lib/libm.so.2
>>         libgcc_s.so.1 =>         /usr/sfw/lib/libgcc_s.so.1
>>         libc.so.1 =>     /lib/libc.so.1
>> Obviously libc.so.6 is missing. On Solaris 10 however libc.so.1 is
>> available
>> under /lib. Is there a secret "configure" switch to have PostGIS call
>> libc.so.1 instead of libc.so.6 under Solaris 10?
>> Thanks in advance.
> Regards,
> Chris Hermansen         mailto:chris.hermansen at timberline.ca
> tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
> Timberline Natural Resource Group · http://www.timberline.ca
> 401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
> postgis-users mailing list
View this message in context: http://www.nabble.com/PostGIS-1.3.3-on-Solaris-10-tp19963091p19963410.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
