[postgis-users] 1.3.4SVN Testers Wanted
Chris Hermansen chris.hermansen at timberline.ca
Tue Oct 14 15:13:13 PDT 2008
OK, so I found two small problems.
First, the error message I mentioned from the run of ./configure:
config.status: WARNING:  Makefile.config.in seems to ignore the --datarootdir setting
Second, despite the comment in README.postgis
> You want to run regress tests before installation.
> To do so, as postgres run:
>     make check
I was not able to get make check to run  until I had done a make install.
The make check did ultimately succeed:
clh at TNRG048:~/src/postgis-1.3.svn$ make check
make -C regress test
make[1]: Entering directory `/home/clh/src/postgis-1.3.svn/regress'
Creating spatial db postgis_reg
TMPDIR is /tmp/pgis_reg_20252
 PostgreSQL 8.3.3 on i486-pc-linux-gnu, compiled by GCC cc (GCC) 4.2.3
(Ubuntu 4.2.3-2ubuntu7)
 Postgis 1.3.4SVN - 2008-10-14 21:53:11
   GEOS: 3.1.0-CAPI-1.5.0
   PROJ: Rel. 4.6.0, 21 Dec 2007
Running tests
 loader/Point.............. ok
 loader/PointM.............. ok
 loader/PointZ.............. ok
 loader/MultiPoint.............. ok
 loader/MultiPointM.............. ok
 loader/MultiPointZ.............. ok
 loader/Arc.............. ok
 loader/ArcM.............. ok
 loader/ArcZ.......... ok
 loader/Polygon.............. ok
 loader/PolygonM.............. ok
 loader/PolygonZ.............. ok
 regress. ok
 regress_index. ok
 regress_index_nulls. ok
 lwgeom_regress. ok
 regress_lrs. ok
 removepoint. ok
 setpoint. ok
 simplify. ok
 snaptogrid. ok
 affine. ok
 wkt. ok
 measures. ok
 long_xact. ok
 ctors. ok
 sql-mm-serialize. ok
 sql-mm-circularstring. ok
 sql-mm-compoundcurve. ok
 sql-mm-curvepoly. ok
 sql-mm-general. ok
 sql-mm-multicurve. ok
 sql-mm-multisurface. ok
 geojson. ok
 regress_ogc. ok
 regress_bdpoly. ok
 regress_ogc_cover. ok
 regress_ogc_prep. ok
 regress_proj. ok
 kml. ok
Run tests: 40
Failed: 0
make[1]: Leaving directory `/home/clh/src/postgis-1.3.svn/regress'
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
