[postgis-users] Indices for ST_distance_sphere
Paul Ramsey pramsey at cleverelephant.ca
Tue Oct 14 17:40:50 PDT 2008
If you're in a planar projection, then
select * from footable where st_dwithin(the_geom, 'POINT(foo bar)', DISTANCE)
will return based on an indexed search for arbitrary foo and bar. You
need to be in a planar projection so the spatial index works in the
same cartesian domain as the distance calculation.
Every planar projection introduces distance/area distortion, the
question is "do you care". Is it big enough to be concerned about,
given your use case.  Variance of +/- 1cm in questions that are need
10m accuracy aren't important.
P.
On Tue, Oct 14, 2008 at 5:31 PM, Stephen Baillie
<steve at alliancesoftware.com.au> wrote:
>> What about 3112 (# GDA94 / Geoscience Australia Lambert) or 3577
>> (Australian Albers), those should cover things fine, no?
> Possibly, although I'm finding it hard to find hard data on what those
> actually mean (let alone what other alternatives are supported by PostGIS).
>  It looks like they still produce range distortion, which answers to my
> previous question on this list gave me to believe would be a problem for
> anything except true spherical distances.
> Closer to the point, though, the choice of projection is of lesser
> importance to my question than that of indexing.  PostgreSQL tells me that
> the spherical distance calculations increase full table scan time by about
> two-thirds when I use those as the where clause of my search instead of
> using a lat/long bounding box, but my question is actually about indexing
> before doing such distance calculations:
> Is it possible to create an index that can be used to speed searches based
> on distance from an arbitrary point, or should I just use a lat/long
> bounding box?
> Thanks,
> Steve.
> Stephen Baillie
> Developer
> Alliance Software
> 1/234 Whitehorse Road
> Nunawading, VIC 3131
> Australia
> Ph:  03 9877 9921
> Fax: 03 9894 2106
> postgis-users mailing list
