[postgis-users] remove polygon from multipolygon
Kevin Neufeld kneufeld at refractions.net
Fri Oct 24 12:20:26 PDT 2008
Yeah, it's a relatively newly discovered syntax that works very well.
http://postgis.refractions.net/documentation/manual-svn/ST_Dump.html
Cheers,
Kevin
Frank Durstewitz, Emporis GmbH wrote:
> Hi Kevin,
> yes, that looks good. I was on that way, but could not figure out, how
> to get the geometry out of the dump rows.
> Very nice this one, i have never seen this ".geom" (and still could not
> find it somewhere in the docs?).
> Many thanks!
> Kindly regards, Frank
> Kevin Neufeld am 24.10.2008 20:44:
>> What about something like this:
>> SELECT ST_Collect(geom)
>> FROM (
>>   SELECT (ST_Dump(geom)).geom
>>   FROM my_multi_polygon_table) AS foo
>> WHERE ST_Y(ST_Centroid(geom)) <= 0;
>> Explode the multipolygon into individual polygons using ST_Dump, and
>> ST_Collect the ones back up again where the centroid falls within some
>> specification.
>> -- Kevin
>> Frank Durstewitz wrote:
>>> Hello list,
>>> i must remove from multipolygon some polygons, for example remove all
>>> polygons from "russia", where latitude of centroid of polygon is <= 0
>>> (in this case the part of russia  which is near alaska).
>>> I think this should be possible (ST_Dump...), but i cannot find any
>>> way to do so.
>>> Deleting the vertices by hand via a desktop gis is painfull slow and
>>> will take ages - i tried this and need ~ 5 minutes for a very small
>>> island of ~ 20 points... (i found no desktop gis where i can select
>>> multiple vertices by a bounding box and delete them at once).
>>> Thanks,
>>> Frank
>>> ST_Summarize gives
>>> MultiPolygon[BS] with 1393 elements
>>>  Polygon[] with 1 rings
>>>   ring 0 has 15 points
>>>   ring 0 has 25 points
>>> postgis-users mailing list
>>> postgis-users at postgis.refractions.net
>>> http://postgis.refractions.net/mailman/listinfo/postgis-users
