[postgis-users] SRID confusion
Paragon Corporation lr at pcorp.us
Thu Oct 30 14:14:36 PDT 2008
Brent,
Are you using AsText or ST_AsEWKT.
AsText to my knowledges doesn't output SRID so it would always be 0.
Hope that helps,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
pcreso at pcreso.com
Sent: Thursday, October 30, 2008 4:53 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] SRID confusion
Hi guys,
I'm not sure what is going on here:
I am working with some strata boundaries for a fisheries survey, mostly
depth based strata. SRID=4326
I also have some polygons of areas of untrawlable seabed & want to generate
these cropped by stratum. SRID=4326
Aas a step in this process I create a new table with a single multipolygon
comprising the geomunion of all the hole polygons. SRID=4326
insert into hole_multi
                select 1, geomunion(geom) from holes;
If I run a query on this table:
select srid(hole), astext(hole) from hole_multi;
I get:
 4326 | MULTIPOLYGON(SRID=0;((55.78 ....
So the SRID of the column is 4326, but each constituent polygon of the
multipolygon, despite coming from a 4326 dataset, seems to be set internally
to SRID=0.
The result is the same with:
                select 1, setsrid(geomunion(geom),4326) from holes;
Any ideas?
Thanks,
   Brent Wood
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
