[postgis-users] Using ST_<function> (doesn't work)
Pedro Martinez Arbizu pmartinez at senckenberg.de
Fri Oct 31 11:06:13 PDT 2008
Have you tried?
select p1.gid, AsText(p1.the_geom_wgs84),
distance(p1.the_geom_wgs84,'POINT(-8.65634368524285
41.1614078251516)') from axes p1 where p1.gid = 7 ;
Pedro
2008/10/31 lisek lichu <lisek.lichu at gmail.com>:
> Hello,
> For last week i tried to find why i can't use ST_ function.
> I have installed PostgreSQL 8.2 version and PostGIS 1.3.3 version
> select version();
> PostgreSQL 8.2.10 on i686-pc-mingw32, compiled by GCC gcc.exe (GCC)
> 3.4.2 (mingw-special)
> select postgis_version();
> 1.3 USE_GEOS=1 USE_PROJ=1 USE_STATS=1
> and when i try to do query like this:
> select ST_distance(the_geom_wgs84,'POINT(-8.65634368524285
> 41.1614078251516)') from axes where gid = 7;
> i get response like:
> No function matches the given name and argument types. You may need to
> add explicit type casts.
> I tried to find some answers but found only digfferences between
> ST_funcion and function but no information about what to do to turn
> them on. If i use normal old function it works but if I add ST_ prefix
> it doesn't. I thik i have new version of PostgreSQL and PostGIS.
> Can somebody tell me why it hapend like that??
> postgis-users mailing list
Prof. Dr. P. Martinez Arbizu
DZMB-Forschungsinstitut Senckenberg
Suedstrand 44
D-26382 Wilhelmshaven
Germany
Tel: +49 (0)4421 9475-100
Fax: +49 (0)4421 9475-111
Email: pmartinez at senckenberg.de
