[postgis-users] Help in making Complex Query
Fred Lehodey lehodey at gmail.com
Tue Sep 2 06:35:48 PDT 2008
Hi Reena,
SELECT t1.* FROM track_points1 as t1, track_points2 as t2
WHERE st_distance(t1.the_geom,t2.the_geom) <= a;
Is that help ?
Fred.
On 8/29/08, S.Reena <reena at indiamail.com> wrote:
> Hello,
> I have two tables track_points1 and track_points2 having wkb_geometry
> columns. I want to make a query that can do this:
> select * from track_points1 where wkb_geometry1 in ( select wkb_geometry2
> from track_points2 where wkb_geometry1= wkb_geometry2 (+/-) a );
> where a is any value (hexadecimal /integer)...
> [basically i want to select one geometry that is in some range of
> another....]
> Can any1 help?
> Cheers,
> Reena.
> http://www.nabble.com/Help-in-making-Complex-Query-tp19217346p19217346.html
> Sent from the PostGIS - User mailing list archive at Nabble.com.
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20080902/074822bd/attachment.html>
