[postgis-users] Any Projected Straights Function?
Simon Greener simon at spatialdbadvisor.com
Thu Sep 11 20:37:03 PDT 2008
Mark,
> I've had a go at this using constraints and plpgsql, which seems more
> intuitive to me:
> alter table rbasin_point add constraint contained_within_basin CHECK
> (assertContains(the_geom, 'containing_table', 'containing_geom_column'));
Not a big expert on PostgreSQL but this (being able to use a function within a CHECK constraint) is very nice feature. Nice addition to my knowledge base on spatial referential integrity.
> Where assertContains is:
> CREATE OR REPLACE FUNCTION assertContains(geom GEOMETRY, container
> VARCHAR, cont_geom VARCHAR)
>     RETURNS bool AS $$
> DECLARE
>     geom_hex VARCHAR;
>     sql VARCHAR;
>     count INTEGER;
> BEGIN
>     geom_hex := encode(ST_asEWKB(geom), 'hex');
>     sql := 'SELECT count(*) FROM ' || container ||
>             ' WHERE ST_Contains(' || cont_geom ||
>             ', ST_GeomFromEWKB(decode(''' || geom_hex || ''', ''hex'')))';
>     EXECUTE sql INTO count;
>     IF count = 0 THEN
>         RETURN 'f';
>     END IF;
>     RETURN 't';
> END;
> $$ LANGUAGE plpgsql;
> The function is a bit of a mess, since I didn't spend much time on it,
> but is this close to what you're looking for?
Good enough, though as it is clear what you are doing.
regards
Simon
SpatialDB Advice and Design, Solutions Architecture and Programming,
Oracle Database 10g Administrator Certified Associate; Oracle Database 10g SQL Certified Professional
Oracle Spatial, SQL Server, PostGIS, MySQL, ArcSDE, Manifold GIS, Radius Topology and Studio Specialist.
39 Cliff View Drive, Allens Rivulet, 7150, Tasmania, Australia.
Website: www.spatialdbadvisor.com
  Email: simon at spatialdbadvisor.com
  Voice: +613 9016 3910
Mobile: +61 418 396391
Skype: sggreener
Longitude: 147.20515 (147° 12' 18" E)
Latitude: -43.01530 (43° 00' 55" S)
NAC:W80CK 7SWP3
