[postgis-users] [OT] Extract data from within polygons - not in Postgis
Martin Davis mbdavis at refractions.net
Fri Sep 12 15:42:17 PDT 2008
You could try using JEQL.  It's a command-line tool which runs on Java,
and provides a SQL-like language for performing spatial processing.
http://tsusiatsoftware.net/jeql/main.html
chlists at me.com wrote:
> Hi list,
> apologies for an off-topic question, but some of you osgeo wizards
> might know an answer for my question. I need some help to do some
> geoprocessing _outside_ PostGIS using available open source tools.
> I have two shapefiles - the first one containing 'master' polygons,
> the second one can contain random features (lines, polygons or
> points). I now want to iterate through all polygons of the first
> shapefile and extract the features from the second file which are
> located within a given master polygon. The extracted features should
> also get some a new attribute based on which master polygon they are
> located in. So essentially it is a  simple iteration over a 'within'
> query.
> Can this be done without converting the shapefiles to a different
> format using any of the existing open source tools (ogr2ogr, geos,
> shapely)? I would prefer to use Python, and if possible, the solution
> needs to be cross-platform (OS X, Win). If not, what would be the best
> way to do this, preserving the attributes of the shapefiles?
> Any pointers greatly appreciated.
> TIA,
> Chris
> postgis-users mailing list
Martin Davis
Senior Technical Architect
Refractions Research, Inc.
(250) 383-3022
