[postgis-users] ArcGIS Mobile slightly off-topic question
Tyler Erickson tyler.erickson at mtu.edu
Wed Sep 17 06:22:28 PDT 2008
I would suggest looking for an ESRI document entitled "ArcGIS 9 -
Writing Geoprocessing Scripts with ArcGIS".  It is about an 80 page
document that gives examples of using python to work with ESRI's
geoprocessor object.  If I remember correctly, I originally downloaded
it as a PDF from ESRI's site, but now I just have the hardcopy.
- Tyler
Paragon Corporation wrote:
> Sorry if my terminology is off here.
> In one of the projects I'm working on,  we are sending out surveyors into
> the field with Mobile ArcPad devices (I think using ArcGIS 9.3 ArcPad
> Mobile) equiped with cameras (I forget the  exact device - I think its
> called Trimble or something like that, but don't hold me to that)  -  I'll
> have to double-check on that if its important to know.
> Anyrate steps ideally
> 1) I dump out the data to geodatabase format which is required by the arcpad
> synch thing.  I was hoping to use OGR2OGR for this, but the OGR driver only
> has read capability for ESRI Personal geodatabase format, not write
> capability and evidentally ArcPad Mobile can only deal with personal
> geodatabase format (or do they have that new sql server express format too
> (adf or whatever the extension is? I forget since this was started in 9.2
> before I think that format was supported).
> So right now I am dumping to esri shape which is loaded into an ArcGIS
> personal database using Arc whatever in steps that are a little less than
> brain-dead.  Luckily I think this only needs to be done once or twice a week
> as opposed to step 2 which probably will need to be done daily.
> Does anyone know how to do this.  Supposedly ArcGIS has python libraries for
> reading and I think writing to Perosnal GeoDatabase which sound like they
> can pull this off, but never used those and I'm pretty green as far as
> Python goes though I'm quite happy to brush up my python skills.
> Any chance anyone has used any of these python libraries and has some code
> they wouldn't mind sharing or has other ideas for doing this.
> 2) When the data comes back from the field, this gets synched up using
> ArcPad or is it ArcCatalog (Arc whatever) I think - pictures are dumped into
> a folder which I think I can  happily pick up, data is dumped into a geo
> database which I think I can happily read and reimport back in to their
> inventory database.
> Thanks,
> Regina
> postgis-users mailing list
Tyler A. Erickson, Ph.D.
Research Scientist
Michigan Tech Research Institute, and
Adjunct Assistant Professor
Department of Civil and Environmental Engineering
Michigan Technological University
3600 Green Court, Suite 100
Ann Arbor, MI 48105
W 83.6889°, N 42.3021° (WGS84)
(734) 913-6846
www.mtri.org
www.michiganview.org
