[postgis-users] ArcGIS Mobile slightly off-topic question
Paragon Corporation lr at pcorp.us
Wed Sep 17 14:32:40 PDT 2008
I want to thank everyone for their suggestions. I'm going to give them a
try.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Gustavo
Ces
Sent: Wednesday, September 17, 2008 10:01 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ArcGIS Mobile slightly off-topic question
Hi Regina,
    easiest way is to create your model in Model Builder and then export it,
as someone has mentionated. Then you can export it as script and modify it.
    There isn´t a lot of info about this topic. Arcgis help is not very
useful ( sometimes the help examples doesn´t work). You have to be careful
with python versions supported by your arcgis version ( there is info in
ESRI forums about how to change your python version, and wich are suported).
There is a geoprocessor model pdf, but no info about toolboxes methods...
It´s a try-error process to understand each toolboxes' methods... And as you
can find  in ESRI forums, sometimes it doesn´t work...
    I´ve got some docs recopilated about this topic. If you´re interested
send me a mail.
Gus
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
