[postgis-users] problems with transformation
Stefan Zweig stefanzweig1881 at web.de
Thu Sep 18 05:40:57 PDT 2008
Thank you regina!
the threads that you have attached show how i can get 4.6 working like 4.5 did. but actually i am quite happy with that what 4.6 does. so ist there a way to get 4.5 working like 4.6?
regards,
stefan
> -----Ursprüngliche Nachricht-----
> Von: "Obe, Regina" <robe.dnd at cityofboston.gov>
> Gesendet: 18.09.08 14:38:10
> An: "PostGIS Users Discussion" <postgis-users at postgis.refractions.net>
> Betreff: RE: [postgis-users] problems with transformation
> Check out these threads and Frank's responses.  I suspect its the same issue you are running into.
> http://postgis.refractions.net/pipermail/postgis-users/2008-January/018400.html
> http://postgis.refractions.net/pipermail/postgis-users/2008-January/018412.html
> Hope that helps,
> Regina
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Stefan Zweig
> Sent: Thursday, September 18, 2008 7:45 AM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] problems with transformation
> hi list,
> im a using two different installations of postgis. the first (1.) is for testing the second (2.) for working.
> (1.)
> select postgis_full_version()
> "POSTGIS="1.3.3" GEOS="3.0.0-CAPI-1.4.1" PROJ="Rel. 4.6.0, 21 Dec 2007" USE_STATS"
> (2.)
> "POSTGIS="1.2.1" GEOS="2.2.3-CAPI-1.1.1" PROJ="Rel. 4.5.0, 22 Oct 2006" USE_STATS"
> i am running the same query on both installations, getting different results:
> (1.)
> select st_y (transform(setsrid(makepoint(-626172.139189,7514065.62361),9805), 4326));
> 55.7765729937296
> (2.)
> 55.9549116318344
> the content for the srids 4326 and 9805 is equal on both installations:
> (1.) + (2.)
> select * from spatial_ref_sys where srid = 4326 or srid = 9805
> srid;auth_name;auth_srid;srtext;proj4text
> 4326;EPSG;4326;GEOGCS["WGS 84",DATUM["WGS_1984",SPHEROID["WGS84",6378137,298.257223563,AUTHORITY["EPSG","7030"]],TOWGS84[0,0,0,0,0,0,0],AUTHORITY["EPSG","6326"]],PRIMEM["Greenwich",0,AUTHORITY["EPSG","8901"]],UNIT["degree",0.01745329251994328,AUTHORITY["EPSG","9122"]],AUTHORITY["EPSG","4326"]];+proj=longlat +ellps=WGS84 +datum=WGS84 +no_defs
> 9805;EPSG;9805; ;+proj=merc +lat_ts=0 +lon_0=0 +x_0=0 +y_0=0 +a=6378137 +b=6378137 +units=m +no_defs
> actually i would suppose to get same results on both installations using transform() if the srid entries on both installations are equal. is there another point than the spatial_ref_sys table where the coordinate systems information can be set?
> to me it seems like installation (1.) calculates the transformation using a spheroid and (2.) using the wgs84 ellipsoid.
> any advices?
> thanks in advance + regards. stefan
> ________________________________________________________________________
> Schon gehört? Bei WEB.DE gibt' s viele kostenlose Spiele:
> http://games.entertainment.web.de/de/entertainment/games/free/index.html
> postgis-users mailing list
> The substance of this message, including any attachments, may be
> confidential, legally privileged and/or exempt from disclosure
> pursuant to Massachusetts law. It is intended
> solely for the addressee. If you received this in error, please
> contact the sender and delete the material from any computer.
Der WEB.DE SmartSurfer hilft bis zu 70% Ihrer Onlinekosten zu sparen!
http://smartsurfer.web.de/?mc=100071&distributionid=000000000066
