[postgis-users] ArcGIS Mobile slightly off-topic question
Burgholzer,Robert rwburgholzer at deq.virginia.gov
Fri Sep 19 05:50:21 PDT 2008
Regina,
If what you are tackling is something that does a cross-walk between a Esri-geodatabase and PostGIS db, I am very interested in this topic.  I am in a mixed media shop, which means I use PostGIS and everyone else uses MS/Esri-centric stuff, and this would really be a leg up for not only integrating PostGIS, but also getting the job done.
I don't know what the appropriate stream for this is, but I will certainly follow any threads on this listserv, or if you want to take it off list, feel free to add my email to any (email in signature below).
I work mainly in PHP, and have written some objects that talk to MSAccess files via ODBC (personal geodatabase), and do some exchange of data with postGres in this fashion.  My current thought on the matter is to simply create a daemon to run in the background and sync my PG database with the personal geodatabase every 5 minutes or so, but would be willing to get my hands dirty with Python if that was the optimal solution.
Thanks, and good luck!
Robert W. Burgholzer
Surface Water Modeler
Office of Water Supply and Planning
Virginia Department of Environmental Quality
804-698-4405
Open Source Modeling Tools:
http://sourceforge.net/projects/npsource/
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Paragon Corporation
Sent: Wednesday, September 17, 2008 5:33 PM
To: 'PostGIS Users Discussion'
Subject: RE: [postgis-users] ArcGIS Mobile slightly off-topic question
I want to thank everyone for their suggestions. I'm going to give them a
try.
Thanks,
Regina
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Gustavo
Ces
Sent: Wednesday, September 17, 2008 10:01 AM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] ArcGIS Mobile slightly off-topic question
Hi Regina,
    easiest way is to create your model in Model Builder and then export it,
as someone has mentionated. Then you can export it as script and modify it.
    There isn´t a lot of info about this topic. Arcgis help is not very
useful ( sometimes the help examples doesn´t work). You have to be careful
with python versions supported by your arcgis version ( there is info in
ESRI forums about how to change your python version, and wich are suported).
There is a geoprocessor model pdf, but no info about toolboxes methods...
It´s a try-error process to understand each toolboxes' methods... And as you
can find  in ESRI forums, sometimes it doesn´t work...
    I´ve got some docs recopilated about this topic. If you´re interested
send me a mail.
Gus
postgis-users mailing list
postgis-users at postgis.refractions.net
http://postgis.refractions.net/mailman/listinfo/postgis-users
