[postgis-users] area resulting from ST_Within
Paragon Corporation lr at pcorp.us
Sun Sep 21 21:07:17 PDT 2008
Surya,
Sorry about that. I realize now I misspoke.
If your watersheds are 1 per record, then the answer should be as simple as
SELECT ws.name,dt.name ,
sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom)))/st_area(ws.the_geom)
As pct
FROM  watersheds as ws INNER JOIN districts as dt
ON ST_intersects(ws.the_geom,dt.the_geom)
GROUP BY ws.name , dt.name , ST_area(ws.the_geom)
ORDER BY dt.name
If they are multiple water shed records with same name and you need to add
them up, then answer is a bit more complicated and probably slower but more
generic solution would be
sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom)))/wa.thearea As pct
FROM  watersheds as ws INNER JOIN (SELECT ST_Sum(st_area(the_geom)) As
thearea, name FROM watersheds GROUP BY name)  As wa ON wa.name = ws.name
        INNER JOIN districts as dt ON ST_intersects(ws.the_geom,dt.the_geom)
GROUP BY ws.name , wa.name, dt.name , wa.thearea
ORDER BY dt.name
 Hope that helps,
Regina
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of surya
Sent: Sunday, September 21, 2008 11:35 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] area resulting from ST_Within
Dear PC,
After summing up  percentage of all districts in one watershed, it does not
add up to 100%. Moreover, after multiplication with 100, the total
percentage of all districts in one watershed  is far below 100%.
In the first watershed, I have 9 different districts. The first district
calculated with the term:
sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom))) gives 25 sq. km,
meanwhile the watershed area itself is 646 sq. km. Therefore, the percentage
of this district should be (25/646)* 100 = 3.9 %.
Using the proposed term tocalculate percentage:
(sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom)))/sum(st_area(ws.the_g
eom)))*100 gives only 0.18 % instead. I do not know what is wrong.
best regards,
surya
 ----- Original Message -----
	To: 'PostGIS Users Discussion'
<mailto:postgis-users at postgis.refractions.net>
	Sent: Monday, September 22, 2008 4:44 AM
	Subject: RE: [postgis-users] area resulting from ST_Within
	Try
	SELECT ws.name <http://ws.name/> ,dt.name <http://dt.name/> ,
sum(ST_area(ST_intersection(ws.the_geom,dt.the_geom)))/sum(st_area(ws.the_ge
om)) As pct
	FROM  watersheds as ws, districts as dt
	WHERE ST_intersects(ws.the_geom,dt.the_geom)
	GROUP BY ws.name <http://ws.name/> ,dt.name <http://dt.name/>
	ORDER BY dt.name <http://dt.name/>
	Sent: Sunday, September 21, 2008 12:42 PM
	Dear Fred,
	Thank you very much. It works correctly !!. I try to further convert
the area of  each district in a watershed as percentage to the watershed
area in question. Please give me more help.
	best regards,
	surya
		Sent: Sunday, September 21, 2008 4:35 PM
		Hi Surya,
		you can try something like that:
		SELECT ws.name,dt.name,
		GROUP BY ws.name,dt.name
		ORDER BY dt.name
		Fred.
		On Sun, Sep 21, 2008 at 3:37 AM, surya
<storma-ipb at indo.net.id> wrote:
			Dear List,
			I have two  tables, one table contains   5 polygons
depicting 5 watersheds or river basin boundaries. Another table contain
district bondaries. Using ST-contain function below, I have obtained
districts belong to a certain watershed . My qestion is how to calculate
area of each district contained in a certain watershed using sum(area)(),
taking into consideration that one district might be splitted in two or more
different watershed
			SELECT watersheds.name <http://watersheds.name/> ,
districts.name <http://districts.name/>
			FROM watersheds, districts
			WHERE ST_contains (watersheds.the_geom,
districts.the_geom)
			GROUP BY watersheds.name <http://watersheds.name/> ,
districts.name <http://districts.name/>  ;
			best regards,
			surya
			postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
