[postgis-users] Comparing Geometries with Different SRIDs
Paragon Corporation lr at pcorp.us
Sat Sep 27 14:06:28 PDT 2008
Charlie,
That is kind of weird.  Although
select 'srid=4326;point(3 3)'::geometry
union all
select 'srid=4325;point(3 3)'::geometry
Works as you would expect since it never has to do any compare between
geometries.
I guess its because at some point to determine uniqueness UNION has to call
something like ST_Equals and since all the PostGIS relation functions are
only supported for geometries with the same SRID it would fail.
So I would say this is a limitation of design rather than a bug.
Thanks,
Regina
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Charlie
Savage
Sent: Saturday, September 27, 2008 4:34 PM
To: PostGIS Users Discussion
Subject: Re: [postgis-users] Comparing Geometries with Different SRIDs
This looks like a related issue:
union
ERROR:  Operation on two GEOMETRIES with different SRIDs
I find that surprising, I would expect to get a result table with two rows.
Charlie
Charlie Savage wrote:
> Here is another SRID issue that seems strange:
> select 'srid=4326;polygon((0 0, 0 5, 5 5, 5 0, 0 0))'::geometry =
> 'point(2 2)'::geometry
> Why not just return FALSE?  I can see forcing the same SRID when
> performing operations such as unions, but if the geometries have
> different SRID's then it seems reasonable to assume they are not
> equivalent.
> Charlie
> postgis-users mailing list
Charlie Savage
http://cfis.savagexi.com
