[postgis-users] Calculating Attributes
George Silva georger.silva at gmail.com
Fri Apr 3 09:22:51 PDT 2009
Hello Aurora,
In ArcGIS it's all different. In PostGIS you can use simple/complex SQL
queries to "calculate values" in a similar fashion of arcgis.
The simplest of them all would be, in your case:
ALTER TABLE table1 ADD COLUMN area_column double precision;
UPDATE table1 SET area_column = ST_AREA(the_geom);
You can in that SQL query divide, multiply, and do whatever you want with
that result that will be written to the column area_column.
I hope that helps
George
On Fri, Apr 3, 2009 at 12:55 PM, Aurora Geomatics <aurorageomatics at gmail.com
> wrote:
> Hello PostGIS users,
> I have just installed William Kyng's PostgeSQ/PostGIS packages for Mac OS
> X.5
> I have been playing with pgAdmin and QGIS with importing shapefiles into
> PostGIS.  Works dandy.
> Now I am wondering how to solve Attribute Calculations.
> Years of using ArcGIS and GRASS it is pretty straightforward on those apps,
> and am stumped with PostGIS Attribute calculations..
> For example, using a polygon feature;
> Creating a new column, say AREA and filling with a calculation that is
> Hectares.
> Thanks!
> postgis-users mailing list
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090403/4f5e0c2c/attachment.html>
