[postgis-users] Calculating Attributes
George Silva georger.silva at gmail.com
Fri Apr 3 10:02:00 PDT 2009
PgAdmin can do it. The terminal can do it too, but i find pgAdmin more easy
to work with.
Just go to the database you are working, open a query editor and try it.
Dont forget about the considerations all the other made. The value returned
will depend on your projection.
george
On Fri, Apr 3, 2009 at 1:48 PM, Aurora Geomatics
<aurorageomatics at gmail.com>wrote:
> Thank you George,
> On 3-Apr-09, at 9:22 AM, George Silva wrote:
> Hello Aurora,
> In ArcGIS it's all different. In PostGIS you can use simple/complex SQL
> queries to "calculate values" in a similar fashion of arcgis.
> The simplest of them all would be, in your case:
> ALTER TABLE table1 ADD COLUMN area_column double precision;
> UPDATE table1 SET area_column = ST_AREA(the_geom);
> You can in that SQL query divide, multiply, and do whatever you want with
> that result that will be written to the column area_column.
> Pretty straight forward SQL statement.
> Is this a matter of opening a Terminal session using psql monitor?
> Is it possible through pgAdmin or QGIS?
> Thanks.
> I hope that helps
> George
> On Fri, Apr 3, 2009 at 12:55 PM, Aurora Geomatics <
> aurorageomatics at gmail.com> wrote:
>> Hello PostGIS users,
>> I have just installed William Kyng's PostgeSQ/PostGIS packages for Mac OS
>> X.5
>> I have been playing with pgAdmin and QGIS with importing shapefiles into
>> PostGIS.  Works dandy.
>> Now I am wondering how to solve Attribute Calculations.
>> Years of using ArcGIS and GRASS it is pretty straightforward on those
>> apps, and am stumped with PostGIS Attribute calculations..
>> For example, using a polygon feature;
>> Creating a new column, say AREA and filling with a calculation that is
>> Hectares.
>> Thanks!
>> postgis-users mailing list
>> postgis-users at postgis.refractions.net
>> http://postgis.refractions.net/mailman/listinfo/postgis-users
URL: <http://lists.osgeo.org/pipermail/postgis-users/attachments/20090403/47c5c516/attachment.html>
