[postgis-users] SQL Loop using ST_Within()H
Paragon Corporation lr at pcorp.us
Sat Apr 4 10:31:59 PDT 2009
SELECT DISTINCT ON (poly.gid) poly.*
FROM PolygonTable As poly INNER JOIN PointTable As Pt
ON ST_Within(Pt.the_geom, poly.polygon_geom)
ORDER BY poly.gid
The distinct on is just in case 2 points fall in the same polygon, we only
want to return the polygon once.  If that will never happen, yo can leave
that out
Leo
-----Original Message-----
From: postgis-users-bounces at postgis.refractions.net
[mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of
diplonics
Sent: Saturday, April 04, 2009 12:16 PM
To: postgis-users at postgis.refractions.net
Subject: [postgis-users] SQL Loop using ST_Within()H
 I have two geometry tabels, one with four points and the other with 70,000
polygons. I want to return all the polygons that contain the four points. I
can easily do this with:
SELECT * FROM polygonTable
WHERE ST_Within((SELECT the_geom FROM PointTable WHERE gid = 3),
polygon_geom);
Is there a way to perform this query in a loop so that I don't have to
change the nested select statement for every point id i need to test.
Any help appreciated, and thanks in advance.
Diplonics
View this message in context:
http://www.nabble.com/SQL-Loop-using-ST_Within%28%29H-tp22885062p22885062.ht
ml
Sent from the PostGIS - User mailing list archive at Nabble.com.
postgis-users mailing list
http://postgis.refractions.net/mailman/listinfo/postgis-users
__________ Information from ESET NOD32 Antivirus, version of virus signature
database 3988 (20090404) __________
The message was checked by ESET NOD32 Antivirus.
http://www.eset.com
