[postgis-users] PostGIS/PostgreSQL - error in creating table
supunmali supunmali7 at gmail.com
Wed Apr 8 06:21:54 PDT 2009
Mark Cave-Ayland-3 wrote:
> This sounds as if you were connected to the database server via the
> template_postgis database which is why you were unable to create a
> database from the template since it was considered active. You need to
> use another database, typically the postgres database generated during
> installation is used for these kinds of administration tasks."
I tried using the postgres database that was created during the
installation, but that too didnt work. Gives the error. Tried using template
DB w/o creating that postgres DB too. But gives the same error.There was no
other databases than the default databases. :(
View this message in context: http://www.nabble.com/PostGIS-PostgreSQL---error-in-creating-table-tp22879914p22950364.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
