[postgis-users] still errors installing postgis 1.3.5 with postgres 8.0/rhel5
Chris Hermansen chris.hermansen at timberline.ca
Fri Apr 17 14:49:14 PDT 2009
Shad;
Your configure run tells you what's wrong.  See the line "configure:
error: Can't find 'flex'"?  It's telling you that you don't have flex, a
lexical analyzer generator, installed.
You need to issue some "yum" or "rpm" command or the other that will
install flex (sorry I don't know what command that is; I use Ubuntu
Linux which uses a different technology called "apt").  You will
probably find other things you need as well as you re-run configure.
These are all "basic development tools", kind of like the compiler.
It looks as though you many not have read
 http://www.postgis.org/documentation/manual-1.3/ch02.html#PGInstall
to see what PostGIS specific things you need (Proj4, GEOS).  Why do I
say this?  Well look again at your config messages: "checking for
geos-config... no" oops no GEOS; "checking for proj... no" oops no Proj4.
Building something from sources on Linux isn't hard, but you do have to
read and understand your configure / make messages to be able to take
appropriate action when things don't finish up the way you hope.
Perhaps you might want to do a bit of background reading in an
introductory Linux book or web-site?
Shad Keene wrote:
> My IT person installed the devel pkgs and the postgis install got a
> little further but still bombed out before finishing.  Any ideas?
> Both postgis 1.2.1 and 1.3.5 failed.  I'm trying to accomplish this
> remotely, so its frustrating that postgis is not installing
> correctly.  Before switching to linux, it was easy to use the
> stackbuilder on windows to install/update postgis.  linux seems to be
> more difficult.  Thanks for any help!
> Shad
> here's the recent error messages:
> checking for pg_config... /usr/bin/pg_config
> checking for geos-config... no
> checking for flex... no
> configure: error: Can't find 'flex'
> [root at zoa-project postgis-1.2.1]#
> [root at zoa-project postgis-1.3.5]#
> Rediscover Hotmail®: Now available on your iPhone or BlackBerry Check
> it out.
> <http://windowslive.com/RediscoverHotmail?ocid=TXT_TAGLM_WL_HM_Rediscover_Mobile2_042009>
> postgis-users mailing list
Regards,
Chris Hermansen         mailto:chris.hermansen at timberline.ca
tel+1.604.714.2878 · fax+1.604.733.0631 · mob+1.778.232.0644
Timberline Natural Resource Group · http://www.timberline.ca
401 · 958 West 8th Avenue  · Vancouver BC · Canada · V5Z 1E5
