[postgis-users] Merge MultiLineString not Ordered
Emiliano Romero eromero at sitrack.com
Mon Apr 20 13:04:03 PDT 2009
I actually mean the start of the second is the START of the first.
That's my problem, ST_LineMerge don't merge them. I'm trying a
workaround with ST_Reverse. But I dont know if this's going to work.
Regards
Paragon Corporation wrote:
> I assume you mean the start of the second is the end of the first?
> Have you tried ST_LineMerge ?
> http://postgis.refractions.net/documentation/manual-svn/ST_LineMerge.html
> Leo
> -----Original Message-----
> From: postgis-users-bounces at postgis.refractions.net
> [mailto:postgis-users-bounces at postgis.refractions.net] On Behalf Of Emiliano
> Romero
> Sent: Monday, April 20, 2009 2:59 PM
> To: postgis-users at postgis.refractions.net
> Subject: [postgis-users] Merge MultiLineString not Ordered
> Hi!, I have a MultiLineString with two LineStrings inside. The start of the
> first is the start of the second one. Is there any way to union/merge into a
> single linestring?
> I could simply use ST_Reverse, but actually there can be several LineStrings
> inside the MultiLineString.
> Any help will be appreciated.
> Regards
> Emiliano Romero
>  This email and any attachments thereof may contain confidential,
> privileged, proprietary, or otherwise private information. This email is
> intended solely for the use of the individual to whom it is addressed. If
> you are not the intended recipient of the email and its attachments please
> inform the sender immediately and do not disclose the contents to any other
> person, use it for any purpose or store or copy the information in any way
> and delete this e-mail and its attachments from your system. Any views or
> opinions expressed are solely those of the author.
> postgis-users mailing list
 This email and any attachments thereof may contain confidential, privileged, proprietary, or otherwise private information. This email is intended solely for the use of the individual to whom it is addressed. If you are not the intended recipient of the email and its attachments please inform the sender immediately and do not disclose the contents to any other person, use it for any purpose or store or copy the information in any way and delete this e-mail and its attachments from your system. Any views or opinions expressed are solely those of the author.
