[postgis-users] [From Oracle Spatial to PostGIS] How to store rectangles?
Mulone andrea.ballatore at ucdconnect.ie
Sun Apr 26 14:19:38 PDT 2009
Hi guys,
I'm porting an application from Oracle Spatial to PostGIS.
In particular I've come across this code in an INSERT statment:
SDO_CS.VIEWPORT_TRANSFORM(
MDSYS.SDO_GEOMETRY(2003,NULL,NULL,MDSYS.SDO_ELEM_INFO_ARRAY(1,1003,3) --
rectangle
,MDSYS.SDO_ORDINATE_ARRAY("+topleftlat+", "+topleftlon+",
"+bottomrightlat+", "+bottomrightlon+")),null)
I understand this loads a rectangle in 2 points.
I've written this postGIS code:
GeomFromText('POLYGON("+topleftlat+" "+topleftlon+" "+bottomrightlat+"
"+bottomrightlon+"))', -1)
Obviously it doesn't work yet. Is this the right direction? Is there a way
to store rectangles in postGIS in a similar fashion?
Thanks,
Mulone
View this message in context: http://www.nabble.com/-From-Oracle-Spatial-to-PostGIS--How-to-store-rectangles--tp23246521p23246521.html
Sent from the PostGIS - User mailing list archive at Nabble.com.
